Trane Thermostat Issue
One of my Trane thermostats has stopped responding to Vera. It works fine in stand alone mode, but no ZWave control. Tried excluding it and re-adding it to the network and it will not exclude either. Any thoughts?
Have you tried power cycling the thermostat? Try and remove the common wire to remove power and see what happens.
  • Garrett
Also, on the [tt]Thermostat Info[/tt] screen (on the t-stat itself), does is still show your [tt]HomeID[/tt] and the [tt]NodeID[/tt] it was assigned to it by Vera?
How far are Vera and the t-stat apart / did you try a full-power exclusion?
::slight_smile: Embarrassed to say that power cycling it worked.
Don’t be … The fact is there was a time when certain things (like thermostats) never required a reboot … While my grandfather and my dad would both be rolling over in their graves the fact is that time has come and gone. :frowning:
On the bright side I can easily turn off the lights in the 2nd floor master suite bath from the bar on my patio. ;D
Ofcourse I can also hear them whispering from the grave … “Why would ever need to do that when we all know the law of the house … Turn the lights off when you leave the room! It’s not rocket science!!” ::slight_smile:
