Trane thermostat Device only shows cool setpoint when in auto mode.
So far the UI5 to UI7 upgrade had been reasonably uneventful for me. However the new display for the thermostat with only one temp control is definitely inconvenient.
Someone please correct me if I’m doing it wrong, but…
To set the heating setpoint via UI7 panel I have to change the thermostat from auto to heat mode, then it will show the heat setting, then I can change the heat setting, then I have to set the thermostat back to auto.
Is there a way to show 2 setpoints if the control is set to auto?
No, there is not in UI7. This has been discussed to death in various threads and requested feature to bring back.
  • Garrett
