Trane Thermostat - changing modes: Normal / Run <-> Energy Saving (ESM)
I’ve never gotten this to work - hoping someone knows how to fix this…
Example:
Manually set the TStat to ESM
Have a Vera scene, or use the Device to select Normal / Run
… nothing happens. It never changes the mode.
Anyone know hot to get Vera to change the mode?
No one can help!?
It’s not obvious … but you can go into Energy Saving Mode with:
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”, “SetTarget” {newTargetValue=0}, ThermostateDeviceID);
And return to previous mode with:
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”, “SetTarget” {newTargetValue=1}, ThermostateDeviceID);
Basically you are treating the Thermostat as a Binary switch!
