I recently installed a Trane thermostat and got everything up and running with Authomation, Tasker and Autovoice. I can turn the heater on and off as well as the AC using Autovoice. Now what I want to do is set the temperature via Autovoice. Is there a solution for this? I fiddled around with Tasker for a good few hours trying to figure this out but I’m stuck.
[quote=“RichardTSchaefer, post:4, topic:178178”]My mistake it’s AutHomation.
These are both available on the Play store.
You can check the forums
General → Remote Control → Specific App Board[/quote]
Ok, thank you!
I’m using Authomation right now. Is there an option in there to do voice settings? I thought I had to do that via Tasker with the Autovoice plugin?
[quote=“garrettwp, post:6, topic:178178”]Are you running AutHomationHD or AutHomation? What version of the app are you running (Click on the About menu option).
Garrett[/quote]
Hi Garret,
I’m using AuthomationHD. App version 3.1.3.9.
Thanks!
