Is the humidity sensor supported in Homewave? I can’t seem to set it up. I have four (multizone) Trane TZEMT500AB32MAA thermostat’s which are basically RCS TZ45 Re-branded for Trane.
They have a RH reading on the stat and in the advanced under Vera is see a “CurrentLevel” line that seems to display humidity.
I can only seem to get the temp sensor reading from Home Buddy. Also I’ll be soon experimenting with the outside temp sensors and or multiple sensor inputs on the stats’s. Before I start is there any support for those either?
Thanks,
JIM
When using multiple sensors for the thermostat, the trane only exposes the main temperature. So if you have the trane setup for averaging of the two temperature sensors, it will only show the average. If you have it setup to use the external temperature sensors, again it will only expose that sensor. It will not report on each individual temperature sensor.
[quote=“garrettwp, post:2, topic:179943”]When using multiple sensors for the thermostat, the trane only exposes the main temperature. So if you have the trane setup for averaging of the two temperature sensors, it will only show the average. If you have it setup to use the external temperature sensors, again it will only expose that sensor. It will not report on each individual temperature sensor.
I have heard about the internal averaging but I was hoping the external setting would allow the outside temp to display along with the internal in each room and possibly report both to Vera also. Sounds like both of these ideas are a no go? Humidity shouldn’t be problem tho right? Do you support them in your app?
