Trane Humidity Reporting
Garret,
 Not sure if it was already added to the list, but I hoping you can add a humidity reading display to your app for the TRANE thermostats.
It’s currently labeled “CurrentLevel” under the advanced tab in Vera or device info in your APP as far as I know.
Tzemt500bb32ma is the specific model I’m using.
Thanks,
Anyone else notice this or have a request for it?
I would like to be able to read humidity as well on this same stat.
[quote=“integlikewhoa, post:1, topic:181074”]Garret,
Thanks,[/quote]
Hi
Does the thermostat report out the current humidity?
http://www.rcstechnology.com/oldsite/docs/thermostats/zwave/TZ43%20INSTALLATION%20MANUAL%20141-01652-04.pdf
Don
[quote=“Don Diego, post:4, topic:181074”][quote=“integlikewhoa, post:1, topic:181074”]Garret,
Thanks,[/quote]
Hi
Don[/quote]
DON,
The RCS you posted the manual on? or the TRANE?
