touch switch + fibaro
Would the following combination work?
A Livolo switch (See here) and a Fibaro relay switch…eg FIB_FGS-221 (or any other switch).
It would be a “cheap” alternative to Vitrum. On the other hand Livolo has a nice range of affordable products.
It would be ideal if someone already has tried this combination :smiley:
Any information is welcome.
Thx
In the mean time i found out that Fibaro is not compatible with capacitive touch switches…so it’s not working.
The only solution for me will be RFXTRX433.
What about using the Livolo doorbell momentary switch? I read near the end of this forum that this could very well be a solution:
http://forum.eedomus.com/viewtopic.php?f=5&t=4244
Here is a similar proof-of-concept.
And another:
I am about to perhaps embark down this route. Does anyone know if the doorbell switches (code VL-C701B) have an LED backlight?
Thanks.
