Hello, I’m new to Vera and home automation in general.
I have the Envisalink EVL4 hooked up to a Honeywell Vista 15p.
I use the app called “Ademco Vista Alarm Panel with EVL3” on the VeraEdge to connect to the Envisalink.
It works fine. I see a virtual device for each zone in my alarm panel as well as a device for partition 1 and a device for the panel itself. The device for each zone responds.
My problem is that I get an email notification whenever a zonedevice is tripped.
Each virtual zone device has an “Armed/Disarmed” switch. If I disarm it, it will tell the alarm panel to bypass the device.
This is the only way I can disable the notification but it is not ideal.
Each virtual zone device has a “Notification” setting but they are blank.
Where can I find the setting to disable the notification?
