Hi Richard,
I am almost sure I am experiencing the following behavior:
- I start a 3-minute Self-Re-trigger PLEG timer. The timer appears as true in the PLEG status report.
- After 2:07 minutes (2 minutes and 7 seconds), I use a ToggleTimer action, to stop the time.
The timer indeed stopped and appears as false in the PLEG status report, with a Last Off timestamp of 2:07 minutes after the Last On timestamp.
However, after another 53 seconds (i.e. 3 minutes after the timer was originally started), I am almost sure the timer “stops again”, as the PLEG staus report shows the timer is still false, but now the Last Off timestamp is 3 minutes after the Last On timestamp, which was not changed.
Is this how PLEG should work, or is it a bug?
Edit: Attached the 2 status reports: after 2:07 minutes and after more than 3:00 minutes.
