TKB TZ77 RGBW Dimmer module was added to Vera as a Generic Z-Wave device.
The device is added as five devices, a main parent device and 4 colour channel devices RGBW etc.
switch_dimmer1 => White
switch_dimmer2 => Red
switch_dimmer3 => Green
switch_dimmer4 => Blue
I renamed the devices appropriately.
Masterbed RGB Dimmer is the parent device and the master dimmer control.
I named each of the individual colour channels.
You could hide the Red, Green, Blue devices from the Vera UI7 web GUI is you wanted too, as its the RGB Controller plugin device that will control the LED strip and setting the colours.
I used the RGB Controller plugin and create a new plugin device and assigned the colour channels. I used the Device Type “RGBW Dimmers”
I am using a RGB LED strip so no actual white.
I renamed the RGB Controller plugin device to Masterbed LEDs this is the device that I will use in the Imperihome app with its colour wheel.
RGB Colour Wheel device in the Imperihome mobile app.
You can change the parent device the “main dimmer” to a Vera RGB device.
To do this go in to the device then select Advanced and on the Params tab change the following:
device_type:
To: urn:schemas-upnp-org:device:DimmableRGBLight:2
device_file
To: D_DimmableRGBLight2.xml
device_json
To: D_DimmableRGBLight2.json
However there are issues with using the parent device for dimming and brightening, read further below.
