TKB Home TZ69E Switch "Failed at : getting the version"
Hi there,
Happy new year to you all
I’ve bought 2 TKB Home TZ69E Switches and have included them on by one into my network, however I am getting the error “Failed at : getting the version” for both of them
I can communicate with them and make them turn on and off - but get the red light on the dashboard and aforementioned error. ALso in my homewave app, I get a red error light too - which usually turns green to confirm that the device has turned off / on as expected.
Could anyone help? I am wondering if it is because these are /z wave plus’ and I am running a Vera Lite with UI 5 - 1.5.622
Thanks!
Hi there,
If you intend to stay on UI5, then you will have to request this firmware version (1.5.672 BETA), for you to be able to use Z-wave Plus devices on your UI5 unit. And even with this firmware only basic devices should work.
For full compatibility you may want to upgrade to UI7 firmware.
Please send our CC team an email ticket (see my signature)
Cool, thanks. Will email you now
Hello I have just upgraded from veralite UI5 to vera plus UI7 and apart from my Fibaro Smoke sensors not reporting the temperature anymore ;-( several of my TKB Dimmer sockets TZ67E are constantly saying please wait getting name which is really annoying, although they are dimming ok, is there a fix for this please
Thanks John M - this patch worked great.
