I have a TKB plugin dimmer for my bedside lights. 2 x 40w normal bulbs.
Vera is programmed to go to 50% around bed time, i might dim it to about 35% manually to actually go to sleep. Vera then has a sleep timer to send an off command to the dimmer after 30 mins.
The dimmer never actually switch off though. Vera reports 0% an it polls as such, but the light is still on the previous set point.
If i manually try to go off again, the output doesn’t change. i can take it to 1% and the state changes, but never off.
Does this sound like a failed device?
Thanks.
