Is there a way to set up a timer to turn light(s) of after x minutes? I want to be able to have an icon on my Android phone that when I tap it, it turns the light(s) off after the predetermined amount of minutes.
Thanks!
Mike
Thanks!
Mike
[ol][li]On the Automation tab, create a new scene and give it a name.[/li]
[li]Click the Immediate dropdown. Then click Manage Delays.[/li]
[li]Look at the bottom of the resulting dialog box. In the Add field type your number of minutes and click Minutes. Then click Close.[/li]
[li]Now, back on the device screen(note the x Minutes dropdown), click the Off button on all of your desired devices.[/li]
[li]Click Confirm Changes.[/li]
[li]Finally click Save.[/li][/ol]
Now, when you run the scene, it will delay x minutes and then turn the specified devices Off.
[quote=“Z-Waver, post:2, topic:182078”][ol][li]On the Automation tab, create a new scene and give it a name.[/li]
Excellent. Thank you!
Now, when you run the scene, it will delay x minutes and then turn the specified devices Off.[/quote]
