Timer not working
This might be a silly question, but when I create a scene that includes a timer command (i.e. light off at sunset), do I have to RUN the scene every time I reboot Vera? Or does Vera know to look at all the scenes you’ve created for scenes with timers and run the timers? Reason I ask is that my timers aren’t working, and I wonder if it’s because I’ve rebooted Vera periodically in the past few months. Please help.
This.
This.[/quote]
In that case…my timers aren’t working!!! I can control the light just fine if I manually “run” the scene or turn the individual light on/off, all via UI4.
Never mind, false alarm. The problem was that the “turn off” scene wasn’t configured correctly to turn off the light device. It works now. The timers work fine. Thanks aavh for the reply, it helped.
