i do experience since quite a while that some scenes with shedule triggers do not fire.
as example i have one scene at 9am turns on the waterpump … but only if my wife has “late shift” … (simple if-then in luup)
well i ignored this for about 3 weeks and listen every morning the moaming that there is no warm water
last night i get to bed arround 2am … and 2 hours later i got shock-waked by my wife because “no warm water”
today i noticed that the 4:00 and the 5:20 scenes also not fire (both are beeing executed only if my wife works “Morning shift”)
the log shows this:
08 02/06/14 5:20:00.100 Scene::RunScene running 39 Zeit 0520 <0x2be79680>
50 02/06/14 5:20:00.101 luup_log:0: Scene 39: Trigger: Schedule 0510 <0x2be79680>
08 02/06/14 5:20:00.202 JobHandler_LuaUPnP::AlarmCallback Ran scene:39 Zeit 0520 / timer:05:20 next at 1391725200 now 1391638800 <0x2be79680>
but the devices stay off.
the scenes are really simple:
4:00 turn on waterpump, and some lights
5:20 turn on the garage and Yard light
here is the luup:
luup.log("Scene 39: Trigger: Schedule 0510")
if ((luup.variable_get("urn:dcineco-com:serviceId:MSwitch1", "Status3", 3) == "1")and(luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 61) == "0")) then
-- yui hat Fruehschicht und away aus
-- front licht an
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" },63)
-- garage licht an
luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" },65)
if i run the scene manually by just clicking the scene button on the UI … it “just works”
log if manual start:
doublechecked on the conditions …
they working fine
luup.log("BOO")
I use a lot of time-based triggers and they work reliably. Did you make sure you are running this everyday? when you open the scene, under schedule, it will show you “last run” is the date and time there correct?
yes they do run every day…
i have confirmed this before writing here. in the trigger window it always show the date correct of the last time it where supposed to run.
even if nothing did happen.
but all it does is:
zero device activity after this … also no error
yes time triggers are reliable, i have quite some of them and they all work… exept 3 of them.
i just 30 minutes ago added another time trigger to the scene with the error … for 1 minute after now … reloaded waitet one minute … and POOF … it did execute it … very strange that is.
Are you sure it’s not one of the two conditions (A,B) in your if (A AND B) logic that is false at times ?
That’s what PLEG Status report will tell you. Pushing the button and having it work only tells me that they are both true at the time you press the button.
Add the state of each to the log file and you can track if the logic is running and skipping you actions because of the state of one of these.
looks good to me …
well i made some other changes … like declaring real numbers and so on
and enable debugging …
i will let the ssh terminal open over night with a tail … lets see whats gonna happen
hopefully i have at least better intel from the debug log in a few hours
it turned out, simply deleting the schedule entry … and create a new one at the same time did solve the issue.
mvc support took a week to respond with “Can you also tell me what do you want to accomplish in that scene? You have selectected device no 3 and device no 61, but I cannot find them on your Dashboard.”
