I’ve got the same issue as mentioned in http://forum.micasaverde.com/index.php/topic,10054.0.html
But are unable to send a PM
A search would yield you many results on correcting the time being off.
[quote=“garrettwp, post:2, topic:173671”]A search would yield you many results on correcting the time being off.
I’ve found a solution for the summertime issue but nothing for the issue found in the supplied link.
It does show the correct time for 2 seconds before it switches to 2010.
It must be a connection issue of some kind. rdate -sp pool.ntp.org gives me a connection timed out as well. All other internet on the vera is working though.
Search for ntp on the forum. There are a few threads that discuss this very issue.
