Thru mios account .. its not recognizing controller. Do i have to reset my vera3
I installed the vera3 smartphone app when I first got it and was always using the app to control my devices.
Now I tried to get the dashboard to work with mios but it’s not recognizing controller. Do I have to reset my vera3 and start from scratch?
Probably not.
Please make sure that you are logging into the correct portal for your Vera.
If you are using UI5, you should login to https://cp.mios.com
If you are using UI7, you should login to https://home.getvera.com
I wound up resetting unit …
Now using cp mios ui7 log in Now working
