Three PLEG apps installed...?
I currently have three PLEG apps:
[tt]Program Logic Event Generator 7.47
Program Logic Core 7.47
Programmable Logic 7.47[/tt]
Do I need all of these installed? I’ve never used PLTS, and I have only one PLEG device out of my four allowed.
PLC is common to PLEG and PLTS … it is where the majority of the code is. So you need PLC if you use either PLEG or PLTS.
You can remove the PLTS plugin. There is a 7.48 version of PLC to fix a bug in the latest UI7 release.
[quote=“RichardTSchaefer, post:2, topic:188774”]PLC is common to PLEG and PLTS … it is where the majority of the code is. So you need PLC if you use either PLEG or PLTS.
You can remove the PLTS plugin. There is a 7.48 version of PLC to fix a bug in the latest UI7 release.[/quote]
Yes, that’s really my question. PLTS used to be called PLTS… which one of the above is it now? By process of elimination… “Programmable Logic?”
I’m still holding off on UI7 until I’m convinced I won’t break anything by upgrading.
The app is listed as Program Logic Timer Switch (PLTS for short)
The other two are:
Program Logic Event Generator (PLEG)
Program Logic Core (PLC)
