[quote=“Z-Waver, post:2, topic:191303”]Welcome back. I’m eager to hear what you did and did not like with SmartThings.
UI7 has improved and continues to improve. But, it’s still got many of the same warts. Right now, the forum is buzzing because Vera just released the Vera Plus a week or so ago. It has more memory than the Edge and also has Bluetooth and Zigbee radios as well. Actually using them is still a work in progress but…[/quote].
Seeing a thread about VeraPlus on sale is what made me rethink coming back. Saw comments about it being mature, etc.
I'm unfamiliar with this feature, so I can;t really answer the question. You can have a switch act as a trigger to run a scene that controls other switches. Just don;t forget that if you don;t have an Instant Status switch, it might take a few seconds to happen.
the few seconds is OK - but it sounds like i might have to get something done in PLEG to answer this.
Nightly heals still occur and the reload of the Vera engine will cause running times to fail. PLEG handles this without a problem.
That stinks. Hopefully I can PLEG it without hassle.
Authomation is no longer being developed. It still works great, but I'd expect problems to start popping up as Vera changes and it doesn't. @garrettwp moved over to openHAB.
I was afraid of that Authomation's voice control was and still is top of the line. Checking status of temps, open close door was awesome. Hope it sticks around without breaking. I too might look into openHAB.
If Vera reboots without Internet, time will be off and scheduled events won't happen in the way that they should. If you remove internet after Vera has booted and gotten the time, then things should function but the clock will likely drift. Vera needs a NTP server to get the time if you're cutting off internet. This is not new. Of course, you'll also lose remote access/control, backups, notifications...
yeah - i think this was an issue in the past - i believe I got my AD controller to respond to NTP. Not sure if i killed that or what. I don't care about remote access - I remote in via always connected VPN, so I have "local" access all the time. And really, if the home/away modes work properly, I don't need to interact while i'm away unless something comes up. So even if the VPN is disconnected, I can reconnect and check in.
@RichardTSchaefer hasn't lied to us yet. Setup correctly his Vera Proximity app works great. Vera's own app and geofencing is pretty terrible.
Geofencing / presence is pretty important at this point. Up until then, I had a semi-smart home. That I had to manually remember to tell I'm away, or have calendar events for the house to know. Arrival scenes firing is not just impressive - but a nice to have. Lights on at night, music, etc, does make a difference.
Can you explain more about this and why you hate it?
It didn't work! It was limited in scenarios where it would work. Only official apps would work. Even though the Aeon Minimotes were supposed to work without the "cloud" it was hit or miss. I have a lot of the "off as toggle" type setups, and all of those fail when Samsung cloud wasn't up. Motion was supposed to be local, but again was hit or miss.
At this point it’s not true local processing the way Vera is.
My thermostat was replaced by Lennox - to a version that is NO longer compatible with SmartThings, and My 3 month old Motion Sensor failed. So, now I have two reasons + lack of proper local processing to dump ST and come back to Vera.
Oh - can you add devices to Vera without having to bring vera to each room (battery/low pwer inclusion)?
