I have been using ThinkEssentials (Pro 2.5.5) to control my 10 devices (outlets, wall switches, a dimmer). It is no longer well supported so I bought Veralite G and am trying to set it up, but am having problems.
I decided to just transfer the primary controller from TE to Vera, and that seemed to have worked. When I view my Devices tab, I see all devices and they do turn on and off ok. But the Dashboard does not show any of them? How do I get it to show the devices too?
I also have an Intermatic HA09 controller which also shows up in my Devices tab, but my TE ThinkStick is not showing as a secondary controller, though it thinks it is now a secondary controller. I am not worrying about it too much as I will remove TE after I get Veralite to work, just thought I’d describe all my symptoms.
I then started creating scenes. I can create a scene, but it does not let me add any devices to it, all devices are striped over and can not be selected. How can I get a scene to include a device?
Finally, I also tried to add a schedule to my scenes and noticed that Veralite does not seem to support a random time feature of TE. In TE you can set something to happen at about 30 mins after sunrise and it will then happen at a random time from sunrise to an hour later. Is there any way to set a Veralite schedule like that?
