Now that Nest has been acquired by Google, I need to look for a different thermostat to use with my heat pump. Does anyone use a thermostat that they really like? I like the high end color changing Honeywell at lowes, but it is wifi only. I do not believe most of the wifi thermostats are supported yet in Vera.
[quote=“garrettwp, post:3, topic:178852”]Not sure I understand the issue here. Why does it matter that Google will own Nest.
Garrett[/quote]
I understand that there may be some “tin-hatting” going on here, but I am not a personal fan of Google and their privacy issues. I also understand that we are giving them our data freely, but that was before an advertising company was involved. Understand that I do not own one, but had asked my father in law to pick on up for me on the way home. When I found out, I told him to hold off.
I went to the Nest forums to check what other people were thinking and those are in melt down mode currently. There are people asking for a return policy now that Google owns Nest. I myself was put off by the fact that Google purposely breaks my old Windows Phone from accessing their services. If I had went through with Nest, I would wonder how much support I would have gotten.
Now after covering the political side, lets talk practical. When I went to the forums, I also discovered that the Nest thermostat is having major issues with heat pump savings. The balance point (Aux Lock Out) is set too high and cannot be moved by users. Several users that are way smarter than me on heat pumps are reporting that this coupled with a bad algorithm used to determine Stage 1 vs Stage 2 usage is resulting in much higher energy usage using the Nest than with a common Honeywell thermostat.
Now having said all that, I may still go with a Nest, but I wanted to see what my options were before I decided totally. If I could find a Wifi/zwave thermostat with humidity controls, I would be happy.
From an energy savings perspective … I helped one person optimize energy savings for his second home.
He knew well in advance when he was going to arrive and did not need a fast temperature recovery to get to the occupied temperature.
He wanted to slowly adjust the set point so that he never dropped into 2nd stage or Aux heat.
[quote=“Reylas, post:4, topic:178852”]Now after covering the political side, lets talk practical. When I went to the forums, I also discovered that the Nest thermostat is having major issues with heat pump savings. The balance point (Aux Lock Out) is set too high and cannot be moved by users. Several users that are way smarter than me on heat pumps are reporting that this coupled with a bad algorithm used to determine Stage 1 vs Stage 2 usage is resulting in much higher energy usage using the Nest than with a common Honeywell thermostat.
Now having said all that, I may still go with a Nest, but I wanted to see what my options were before I decided totally. If I could find a Wifi/zwave thermostat with humidity controls, I would be happy.[/quote]
I think Ecobee has a thermostat that would fit your needs. I follow their user discussion group ([url=http://groups.google.com/group/ecobee-users/topics]http://groups.google.com/group/ecobee-users/topics[/url]) and the vendor is active on it and seems obsessed with getting the details right, like proper heat pump control, frost control algorithms, etc. Some models control humidity; all report it. There is control from the web, a mobile app, and a Vera plugin. While the Ecobee has a little less glitziness than the Nest, it seems like they instead invested in getting the thermostat right in the details that matter.
Thanks for the recommendations! I will check out the ecobee and see. And thanks for ignoring the politics, I really did not want to devolve into that. I am pretty agnostic about it, but fear what may happen without an open API.
Then when I saw the heat pump issues, I decided to look again. I would be open to using PLEG, but need humidity control as well, and the cheaper stats don’t seem to include that.
I tried the wiki, but plugin development seems to be moving quicker than it is
[quote=“RichardTSchaefer, post:5, topic:178852”]From an energy savings perspective … I helped one person optimize energy savings for his second home.
We did this with the help of the PLEG plugin.[/quote]
@RichardTSchaefer, that is a great idea that I hadn’t thought of. Our vacation home will sometimes have to be cooled by as much as 10-15F. Making sure that the temperature set point is moved up 1degree at a time (versus the 2degree differential needed to kick in the 2nd sage of the A/C) would make sure that we are cooling the house in a linear fashion and with minimal energy. The only question I have is that in this case, the A/C unit would cycle off and you would have to wait the (10min) period required to re-start the A/C.
I guess I could change the unit to cycle the 2nd stage with a 3 degree differential and avoid having the unit turn off…
From a cooling perspective … the slower change will also remove more humidity than the faster cool down.
In the winter … the slower change will keep the heat pump running … and not allow the aux-heat to kick in.
It might be better to have a 2,3,4 deg deltas for the different stages.
