Thermostat HRT4-ZW controlling the receiver without Vera ?
I have a (hopefully temporary) problem with my Vera lite, it is out of action. So until i get it working again or get a replacement, i have no controller. I have set up my Thermostat HRT4-ZW with the 2 channel receiver (2nd channel for hot water). The HRT4-ZW controls the heating channel. I think when i set it up the receiver has a seperate deice in Vera UI, and i am quite sure i set it to be directly controlled by my HRT4-ZW. Now after having had to remove my Vera, the little aerial symbol on the HRT4-ZW still shows connected, but it does not seem to control the receiver any more. I can manually override on the receiver and turn the heating on/off, but there is no thermostat control. It would be good to have the thermostat still control the receiver, i though that was the case when you put in a direct control. But that does not seem to be the case. I am not sure i can change that now without the controller, but for future reference and if my controller fails again i would liek to know if it is possible and how to set it up that at least the thermostst still controlls the heating without a controller
I have the same Thermostat. It controls all electric panel heaters on my main floor. I have recently switched from HomeSeer to Vera so I can not give you in depth advice. I want the Thermostate to work even if Vera goes down as heating duing winter in Scandinavia is absolutely nessesary. To achive this I have a dedicated swicth (Fibaro) for each penel which are assosiated with the Horstman. The Horstman is included in the Zvawe network in the ordinary way. This seems to work ok in terms of the Thermostate controling the panels even if the Vera is turned off.
You could try to exclude the Horstman from the network until your Vera is fixed. If you do not have any controler this is difficult unless you reset the Horstman to factory setings and then pair it agin with the devices you want to control.
Hope this helps!
