So my wife and I recently bought a new home that has radiant floor heating on 4 zones. The heating is controlled by old mercury round thermostats, that I am eager to replace. I popped one off the wall, and found that there are only 2 wires connecting them, but a quick multimeter test showed a 24V current.
Ideally I would love to setup z-wave controlled systems for all zones, but I am a bit baffled by all the different thermostats/wiring requirements out there. Would anyone be able to help me understand what my options are?
The two wires are supplying current to the solenoid that gives water to that zone. One is power and the other goes to the solenoid…the solenoids all have a common wire tied to the power supply as well. Any Zwave thermostat could turn the solenoid on and off but the thermostat will need 24 VAC as well. Can you tag in another wire to supply them with power?
Tim
Depending on thermo, it generally has an option for batteries or external 24v power.
Battery life is quoted as 2 years, I’m only into 2 months so I can’t comment on the actual life.
ON the plus side, battery condition is transmitted, so a flat battery won’t catch you off guard.
Thanks for the help guys. So, am I to understand I need another wire in order to use a ‘normal’ thermostat? If so I’m probably out of luck, as running another wire seems like I would be asking for trouble.
I’m not really a fan of apple products, and I wanted to get a Veralite to manage my z-wave stuff, but I did read somewhere that the Nest might be able to work on a ‘two wire’ setup. Is this true? If so, might there be other similar products out there that could work? If not, and I can’t run wires, are my options limited to battery based units? Perhaps a 2gig CT100?
I’m using it as a 2 wire system, not so different to what you have, except mine is for Gas Ducted Heating.
Have a read of the product info, it will fill in the missing gaps.
