Thermostat for in floor hydronic with slab sensor?
Hi all,
Having no luck finding a solution so thought I’d check if anyone else has- Looking for a low voltage z wave t-stat that supports input from a floor sensor- I have hydronic in floor radiant throughout the house and need to monitor the temperature of the slab on the main floor due to engineered wood flooring.
Anyone have any luck finding a product? Only thing I’ve found so far is line voltage made by Heatit.
