I have an Intermatic Z-Wave InTouch Thermostat(CA8900), which is claimed to be the same as a Wayne-Dalton WDTC-20. It seems to work fine (just installed it today), except that the Fan indicator on the MIOS dashboard always says “On”, even when I select “Auto” (and even when I go press “Auto” on the thermostat). What’s up with that? Thanks.
What firmware are you running?
This was fixed recently for the Trane stat which I presume was the same for all T-stats.
JOD.
I’m running 1.1.1047.
If I need to update the firmware, can you either tell me how or give me a pointer to somewhere I can read how? Thanks.
You can upgrade using the link in the post below
I believe the fan always shows on in 1047 for any tstat. It does on my Intermatic.
