I need 4 thermostats that are compatible with the Intellizone (1st generation) system. Anyone know? I’ve tried contacting Waterfurnace, but they want you to use only self-branded tstats.
I don’t know anything about the Intellizone system, but I’ve been searching for answers to my own unique thermostat situation recently. I suspect it will depend on if your system uses some sort of proprietary communication. If each zone has a thermostat that does its own thing, then you might have quite a few choices. Here is a thread here that you might find helpful.
