The green power light is blinking green forever when powered on
Just got my Vera3 unit and started it, plugged the network cable into the WAN port and then to my router, then powered it on.
The green power light is blinking green, it has been doing that now for 45 minutes. Unplugged the power and started it again with the same result.
Have tried the reset and help buttons on the front as suggested in this forum. Also tried connecting the network cable directly to my laptop but I don’t even get an IP adress.
Is it bricked? What to do?
Thanks!
You’ll need to contact MCV support.
  • Garrett
P.s. make sure you are using the correct power adapter.
