[quote=“akbooer, post:53, topic:186459”][quote=“RichardTSchaefer, post:50, topic:186459”]A root cause to this was the removal of “Event Watcher”
The real root cause was probably lack of memory, which required the removal of “Event Watcher”.
MCV does not provide a hook to the app (plugin) developers that runs before a plugin is deleted.
Event Watcher uses the Alternate Event server API for Vera. When you remove Event Watcher you must disable it.
In this case Every Event that was generated after “Event Watcher” was removed was queued up.
And all of these events were trying to get delivered … and failed … so they kept accumulating and retrying.
I guess “Event Watcher” needs a “Click ME Before Uninstalling Me” button some where.[/quote]
Actually, at the risk of double-posting (See here [url=http://forum.micasaverde.com/index.php/topic,31596.msg228711.html#msg228711]http://forum.micasaverde.com/index.php/topic,31596.msg228711.html#msg228711[/url]) but aiming for clarity, let me re-iterate:
[tt] [/tt]“This is a problem with Vera’s Alternate Event Server, (rather than EventWatcher, per se) which you must have enabled some time. Unfortunately, their recipe for turning it off doesn’t seem to work.”
I refer to the information posted here: [url=http://wiki.micasaverde.com/index.php/AlternateEventServer]http://wiki.micasaverde.com/index.php/AlternateEventServer[/url]. In particular, the suggestion:
[tt] [/tt]To stop logging to your own server, call the variableset again but leave the Value empty.
…does not seem to work reliably. I assume that you could hack the UPnP User Data to remove the AlternateEventServer reference, but I haven’t tried that myself.[/quote]
I tried setting the value to and to 127.0.0.1 and neither made any difference. In the end the repeating flood was killed by tech support deleting them from the /persist/ folder. That however does not appear to be the case with the camera message I posted on EventWatcher thread, those its generating fresh
