I replaced a “White-Rodgers” TS with a Honeywell TH8320ZW. I had to connect the blue wire at the furnace to the common post, and connected it at the TS, other than that, all wiring was the same. I powered it up and set it to cool and set the temp well below the room temp. 5 minutes later, the system begins to cool. Everything is fine for about 20-30 minutes at which time heat starts coming out of the registers instead of cold air. I went down to the furnace and the furnace is running (gas furnace), so I go outside to the condenser and it is also running and I feel the hot exhaust coming from the PVC out of the furnace. My furnace/AC is an “Achiever 90 Plus”. Standard furnace and single speed condenser. I have cut and stripped fresh wire to make sure I have no “shiners”. I’ve verified nothing is shorted across terminals, etc… I’m kind of at whit’s end. Did I get a faulty thermostat or is something else going on? It is not a heat pump system, so the reverse valve isn’t an issue.
I hooked the old TS back up (without the Common wire) and it runs fine. I went out and verified the condenser is running, but no exhaust out of the furnace.
Thanks!
(this is cross posted on another forum)
