TFA 30.3039 Support (IT+)
Hello,
I own the following device:
vvv.amazon.de/TFA-303039-HygroLoggPro-Profi-Thermo-Hygrometer-Datenloggerfunktion/dp/B004HZC3LS/ref=sr_1_2?ie=UTF8&qid=1327006195&sr=8-2
and a set of sensors. I found it very nice and I wonder if this would be possible to use it with Vera3 ?
The options would be to get the signal from the sensors directly (433Mhz) or talking to the ‘base’ via the provided USB receiver.
Did anyone succeed on using this device? The good things about it are:
  • wireless (I get values from 2 floors below)
  • no cables, not even for power (batteries)
  • temp + humidity
  • buffer on the base that hold around 1 month of data for one measure every 5 seconds (on the base + 8 sensors, so 9 measures for both humidity and temp)
  • possibility to set alerts high and low on temp and/or humidity of any sensor
  • possibility to NAME the sensors on the base
Yes I like it :slight_smile: I have no Vera (yet?) to try though.
Now that I have a Vera I can add to the benefit of the TFA devices above that it is much more accurate than the thermostat from Hostmann for instance. I don´t give up the idea :slight_smile:
