Text from door sensor help please.
Everspring door/window sensor. I created a trigger where that when the sensor is armed and someone opens the door, I get a text that the door was opened. The problem is that every time I just arm the sensor I get the email. I am about to add an additional 20+ sensors and don’t want the initial text when I arm every sensor. Only want the text if the armed sensor was triggered. Any help will be appreciated.
Do you arm these one at a time ? Or do you arm them from some script ?
