Test Luup Code taking a long time
All of a sudden, yesterday Pressing go on the Test Luup Code page (even with really simple lua code) started taking up to 2 or 3 minutes to actually run on the device and return.
If I watch the logs, other things are happening in the LuaUPnP.log file, and eventually I see my submitted code shortly before the page responds.
My gut makes me feel some network connection is timing out on the vera, but I can see the port get opened on the vera and data get sent, and eventually I will see a response on the wire.
Anyone else had this happen to them before?
I am having the same problem. Did you get it resolved?
I recommend rebooting your Vera and uninstalling any unused plugins. If you aren’t using the Energy plugin, remove it.
