Hello
I’m a new one in vera but I think I have some issues with the luup engine. I tried to develop just a simple luup code. I did the test in the develop apps → test luup code (lua)
this was my code
local x = 1
I know it’s very very simple but I did that for some reason. After pressing go the message “sent sucesfully” came back.
Then I created a little bit more complex one
local deviceNo = 6
local SS_SID = “urn:micasaverde-com:serviceId:MotionSensor1” – Security Sensor Service ID
local armed = luup.variable_get (SS_SID, “Armed”, deviceNo)
if (armed == “1”) then
return true
return false
This ends with code failed and the firebug is saying 500 internal server error. I though that there is an issue with my code so I deleted everything and went back to the code
local x = 1
but this is ending with the code failed too. tho only thing to get even the local x = 1 working I have to reboot the vera lite.
This is the response after I click on the go in test
You may not be doing anything wrong. The “test Luup code” box will say Code Failed whenever your code returns false. This makes it somewhat unhelpful. I advise users to avoid it.
The 500 Server Error might not be telling you anything useful either. It may be that way by design.
Thank you guys for the reply.
futzle could you please advice what should I use for the debugging? and I do not understand why the test said error code even from local x = 1. there should be no issue.
garrettwp thank you very much also for the info. I was not aware that I’m running the old firmware as according to the firmware tab in my vera lite I was running the latest one. I just upgraded to 1.5.622 as you recommended.
Unfortunately the behavior of the test luup code is the same. It looks to me like after putting one wrong there it’s “frozen” and ever the right code then is ending with code failed. Which is really not good. Could this be a bug?
This is just a guess: A statement like “local x” or an if-statement is neither true nor false. Try an indisputably true statement like “return true” and see what it does.
I normally advise that you just bang the Luup code straight into the scene you want it to live in. You’ll need to watch the Luup log to see what’s going on, but learning to read the Luup log is IMO unavoidable so you may as well get used to it.
If you want to keep using the Test Luup Code box, be aware of its limitations. Stick a “return true” at the end and don’t return anywhere else. Use luup.log() if you want to see the value of a variable, and inspect the Luup log to see what it prints.
Exactly. [tt]local x=1[/tt] may yield ‘success’; a subsequent [tt]return false[/tt] will yield ‘fail’; a subsequent [tt]local x=1[/tt] now yields ‘fail’.
thank you very much
you were right.
the return false caused it. I most probably did not know correctly how it works. I though it’s for checking the code → if the syntax is ok.
So I was waiting for some code ok, result is false (of the code run). Thank you again for your help it’s working ok now.
Is there some other tools for luup development? for example for vim or something else or what are you using please?
thank you
