Reading this forum for a while and I though I knew what a “reboot” was, however not I’m not sure.
I have a VeraPlus, and if I query the controller with “http:///cgi-bin/cmh/log.sh?Device=LuaUPnP” I get the log which shows every 6 minutes a group of lines starting with " -rw-r–r-- 1 root root " See attached.
Is this a reboot or is it something else (hopefully normal)?
Part of log:
06 02/25/18 16:00:14.667 Device_Variable::m_szValue_set device: 57 service: urn:upnp-org:serviceId:TemperatureSetpoint1_Heat variable: CurrentSetpoint was: 68.00 now: 68.00 #hooks: 0 upnp: 0 skip: 0 v:0xde5c08/NONE duplicate:1 <0x769d9520>
06 02/25/18 16:00:14.667 Device_Variable::m_szValue_set device: 57 service: urn:upnp-org:serviceId:TemperatureSetpoint1 variable: CurrentSetpoint was: 68.00 now: 68.00 #hooks: 0 upnp: 0 skip: 0 v:0xde4ed8/NONE duplicate:1 <0x769d9520>
06 02/25/18 16:00:14.667 Device_Variable::m_szValue_set device: 57 service: urn:upnp-org:serviceId:TemperatureSetpoint1 variable: AllSetpoints was: 68.00,1.00,34.50 now: 68.000000,1.000000,34.500000 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x769d9520>
06 02/25/18 16:00:14.668 Device_Variable::m_szValue_set device: 57 service: urn:upnp-org:serviceId:TemperatureSetpoint1 variable: AllSetpoints was: 68.000000,1.000000,34.500000 now: 68.00,1.00,34.50 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x769d9520>
04 02/25/18 16:00:14.679 <Job ID="8423" Name="pollnode #32 5 cmds" Device="57" Created="2018-02-25 16:00:06" Started="2018-02-25 16:00:06" Completed="2018-02-25 16:00:14" Duration="8.578083000" Runtime="8.576756000" Status="Successful" LastNote="" Node="32" NodeType="ZWaveThermostat" NodeDescription="Family_Room"/> <0x769d9520>
02 02/25/18 16:00:14.679 Device_Basic::AddPoll 57 poll list full, deleting old one <0x769d9520>
06 02/25/18 16:00:14.680 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:HaDevice1 variable: PollRatings was: 5.00 now: 5.00 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x769d9520>
06 02/25/18 16:00:14.681 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastPollSuccess was: 1519592214 now: 1519592414 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x769d9520>
06 02/25/18 16:00:14.681 Device_Variable::m_szValue_set device: 57 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: ConsecutivePollFails was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x769d9520>
01 02/25/18 16:00:24.165 UserData::WriteUserData saved--before move File Size: 34483 save size 34483 <0x767d9520>
02 02/25/18 16:00:24.166 UserData::TempLogFileSystemFailure start 0 <0x767d9520>
02 02/25/18 16:00:24.187 UserData::TempLogFileSystemFailure 4931 res:1
-rw-r--r-- 1 root root 33 Jan 30 15:00 /etc/cmh/HW_Key
-rw-r--r-- 1 root root 33 Feb 26 2016 /etc/cmh/HW_Key2
-rw-r--r-- 1 root root 9 Jan 30 15:00 /etc/cmh/PK_AccessPoint
-rw-r--r-- 1 root root 7 Jan 30 15:00 /etc/cmh/PK_Account
-rw-r--r-- 1 root root 4666 Feb 25 12:02 /etc/cmh/alerts.json
-rw-r--r-- 1 root root 0 Jan 30 00:02 /etc/cmh/cameras
-rw-r--r-- 1 root root 423 Jan 30 15:00 /etc/cmh/cmh.conf
-rw-r--r-- 1 root root 0 Feb 12 2016 /etc/cmh/devices
-rw-r--r-- 1 root root 16383 Feb 3 03:00 /etc/cmh/dongle.4.5.dump.0
-rw-r--r-- 1 root root 16383 Feb 1 03:00 /etc/cmh/dongle.4.5.dump.1
-rw-r--r-- 1 root root 16383 Jan 31 03:00 /etc/cmh/dongle.4.5.dump.2
-rw-r--r-- 1 root root 16383 Jan 30 03:00 /etc/cmh/dongle.4.5.dump.3
-rw-r--r-- 1 root root 16383 Jan 29 23:49 /etc/cmh/dongle.4.5.dump.4
-rw-r--r-- 1 root root 16383 Jan 29 23:49 /etc/cmh/dongle.4.5.dump.5
