Hi all!
I’m a bit lost with a special use-case in my Vera setup.
I have a door sensor and a wall-switch. I want the door sensor to trigger a push message to my phone if it is trapped. However if it is trapped and the wall-switch gets switched on and off again within the first 20 seconds after the door sensor was trapped, I want no push message but I want to disarm the door sensor to get disarmed for 2 minutes.
Sounds pretty easy but I could not figure out how to get this task done.
I hope somebody can help me with this!?
Thanks a lot in advance!
[quote=“gatogatogato, post:1, topic:181797”]Hi all!
Thanks a lot in advance![/quote]
Use PLEG:
http://rts-services.com/Vera/Plugin/PLEG/example/twostate.html
Thanks for the reply - but after reading the example I am just more confused. I even bought the license for the PLTS/PLEG but I just can’t manage to get it running as I described.
Can you give me a more specific hint?
[quote=“gatogatogato, post:3, topic:181797”]Thanks for the reply - but after reading the example I am just more confused. I even bought the license for the PLTS/PLEG but I just can’t manage to get it running as I described.
Can you give me a more specific hint?[/quote]
If you want to trigger stuff within 20 seconds, PLEG is no option for you as it evaluates its timers every (whole) minute. Minimum interval with PLEG is therefor 1 minute. Use a countdown timer instead, and set it to run 20 seconds. Try something like (in PLEG, after downloading and setting up the countdown timer):
Triggers:
ArmedDoorSensorTripped – Door tripped while armed
WallSwitchOn – Device is turned on
TimerCompleted – Countdown timer finished after running for 20 seconds
Conditions:
StartTimer - ArmedDoorSensorTripped – Start the 20 seconds countdown timer when the armed door sensor is tripped
CancelTimer/DisarmSensor - (StartTimer;WallSwitchOn) AND (WallSwitchOn;!WallSwitchOn) – cancel the timer and disarm the door sensor when (wallswitch turned on after the timer was started) and (wallswitch turned off after it was turned on)
SendPushMessage - TimerCompleted – when the timer completes (wasn’t cancelled by the condition above), send a push message
This is NOT true.
The prefefined NOW timer is evaluated every minute.
There are plenty of examples of PLEG that use accurate sub minute timers … They use Self (RE-) Triggered timers. They require a few more steps compared to using NOW.
See Rex’s excellent guide for using these:
http://forum.micasaverde.com/index.php/topic,21603.0.html
[quote=“duiffie, post:4, topic:181797”]Triggers:
Conditions:
SendPushMessage - TimerCompleted – when the timer completes (wasn’t cancelled by the condition above), send a push message[/quote]
Heureka! This did the trick. Thank you so very much!!! Obviously it’s easy when you see it :o
[quote=“RichardTSchaefer, post:5, topic:181797”]
This is NOT true.
http://forum.micasaverde.com/index.php/topic,21603.0.html[/quote]
Thanks for mentioning the manual. I did not know this before. I will have a look at it for my next project.
Actually I found the examples on your website a little bit too short - I guess they are only helpful for more experienced PLEG/PLTS users.
