Temporarily disabling Z-wave devices without removing them from Vera
Hi @oTi@
they are back in situ but until my other issue rectified is hard to tell of improvement. is there a way to check my “node table” if you will excuse the perhaps odd expression. to see if io have all noted nodes present and as such identify if I have other, now removed nodes, still showing as present that i need to flush from the mesh?
The Info Viewer plug-in can produce a matrix that shows all nodes and ‘who sees who’ (and a whole bunch of other info; also has a log viewer).
Oh yes have seen that - very useful - thank you.
