Installed this and tried to understand how it works - to be able to change it a bit.
It replaces the D_TemperatureSensor1.json and S_TemperatureSensor1.xml files with its own versions - apparently the ones in /etc/cmh-ludl directory override the ones in /etc/cmh-lu directory.
But each time LUUP restarts and everything is initialized again - those files are being:
- downloaded again (with different name where Sensor1 has been replaced by Sensor11)
- renamed from Sensor11 to Sensor1
Could somebody please explain why is it necessary to download them each time again - and how those files just disappear when LUUP restarts. At least I suppose they disappear because otherwise the rename command would fail…
