Temperature Display
I have 11 zwave thermostats in the house. One for each room and some rooms have two. They all control in floor (radiant) heat.
Have anyone created an app that could poll temperature from all available thermostats or temp sensors and display in one place?
Or how do I create a display like this?
Are you looking for an average of all of the temperatures or showing of each temp in one location?
For the average, have a look here:
http://forum.micasaverde.com/index.php/topic,16215.0.html
  • Garrett
Really just looking for the current temperature. However many displayed in one “box” so it does not take up too much space.
Have a look at the variable container plugin.
  • Garrett
So I found and modified the following to suit me and put it in the Startup LUA. It works great. How do I make it refresh when temp changes or hourly?
local idtemp1 = Temp_Living_North
local idtemp2 = Temp_Living_South
local idtemp3 = Temp_Foyer_Guest_Bath
local idtemp4 = Temp_G0_Bath
local idtemp5 = Temp_G0_Bed
local idtemp6 = Temp_G1
local idtemp7 = Temp_G2
local idtemp8 = Temp_G3
local idtemp9 = Temp_BM
local idvcontainer = 342
local idvcontainer2 = 343
local temp1 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 4)
local temp2 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 3)
local temp3 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 5)
local temp4 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 7)
local temp5 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 6)
local temp6 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 8)
local temp7 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 9)
local temp8 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 10)
local temp9 = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”, 13)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable1”,temp1,idvcontainer)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable2”,temp2,idvcontainer)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable3”,temp3,idvcontainer)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable4”,temp4,idvcontainer)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable5”,temp5,idvcontainer)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable1”,temp6,idvcontainer2)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable2”,temp7,idvcontainer2)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable3”,temp8,idvcontainer2)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable4”,temp9,idvcontainer2)
return true
Put the Lua in a scene instead of Startup Lua and schedule the scene to run at the required interval.
Awesome - the help I needed. Thanks guys.
Thx used this as well
