Temperature control
Hi, is it possible to make a scene where you messure 2 temperatures and make a heater control the difference so it will always be 4-5 degrees between them?
(always 4-5 degrees varmer inside than outside)
Or do i need a Luup code? ???
You can do this with the Program Logic Event Generator plugin.
