Hi, a suggestion for a future release: If I have one or more temperature sensors, I would like to be able to see a graph of the temperature for each sensor over time. I would also like to see the power usage as a timed graph.
The reason I want this is to be able to fine tune the time I switch on the heating, correlated with outdor temperature. This applies both for the morning and when I come home from work. By the way I have electrical floor heating as the main heating (electicity is dead cheap in Norway and since it is 99% hyrdo electric it means no C02 or atomic waste )
I could always do the graphing in Excel if I had the data available, so that got be a start.
I guess Lua can solve the problem of turning on at the right time.
The first one is a multi sensor (4-in-1). The US version is HomeSeer HSM100, was discussed here a lot. It has motion detector, light, temperature and battery level sensors. Vera now supports HSM100, but only the motion detector part. MCV promised to add the rest soon: http://forum.micasaverde.com/index.php?topic=8.30
Doesn’t seem to work for me even on 1.0.488, see attachments.[/quote]
The HSM that I have does not work either.
I was told that it is an older version that works on the multi instance class and not the current Multi command as does the more recent HSM100’s
I am glad I found someone with the same problem. I have the same errors and also bought as smarthus hope they fix it soon. I sent my info to support twice (second time today only). Let’s hope they fix it.
Will need to go back to PC / Homeseer for the moment.
We’ve identified a problem with the Euro versions of these Express controls motion/temp sensors. I hope to have it fixed within a couple weeks. When I have a patch I’ll let you know.
