Was doing some testing to see if temperature based alerts were working any better in latest release and so far it seems they are worse, I used to get low temps to trigger an alert but not hight temps, now it seems neither works correctly (at least in todays testing) anyone getting temperature based actions/alerts to work correctly? I’m using HSM-100 but dont know if that matters should work the same as a thermostat
