Temp and humidity?
Got a strange problem when using Imperihome Pro, my temp and humidity devices works in one room (with an Everspring sensor), but all the others just show N/A. These includes both other identical Eversprings and weather plugin devices. They all work in Automation and the Vera GUI. Any tips?
Sent from my Nexus 10 using Tapatalk 4
Hmmm strange thing : does it persist after a forced reload ?
Would you be able to send us (contact@imperihome.com) an extract of your user_data json file, so that we can diagnose and find the problem ? (http://ipaddress:3480/data_request?id=user_data2&output_format=json) be careful : you’ll want to obfuscate some confidential informations from the file (eg ip cam credentials, etc…)
Best regards,
Found a workaround, do not use the “show no room group” setting.
