I called tech support, and got connected to customer support, who can’t help me with my technical questions.
Time to box this thing up and send it back?
Questions:
Complaints:
I’m sorry that I can’t answer about the new Vera form factor as I have to old one. I do know that the IP cameras were very easy to setup (some may require some manual settings, but my Panasonic was automatic).
1?
2?
3 You should already have UI3 with the new Vera, but to upgrade firmware go to Advanced in the pop-out menu on the right andthen click the Firmware or downloads tab. Copy/paste the URL for the firmware into the field and click download. After you download it, you’ll want to click backup to save a copy on your PC before upgrading the firmware. You can find the firmware links in various places, but the central location is on the forum under official announcements.
4 You might submit a ticket for this, it can probably be resolved by support very quickly if you submit a ticket.
I am looking at firmware version 1.0.989, which I believe is UI2.
Since I don’t have UI3, I don’t have the pop out menu item you described.
in UI2 Click “Setup”, Then “Advanced”, then “Downloads”. Paste the firmware URL into the input box, click “Download” and follow the instructions.
Hi all,
Rick, I answered your request the moment I read the ticket. I hope you’re not so upset anymore with the technical support.
[quote=“Rick-OH, post:4, topic:165853”]I am looking at firmware version 1.0.989, which I believe is UI2.
Since I don’t have UI3, I don’t have the pop out menu item you described.[/quote]
Sorry Rick, I got a bit confused there myself. No pop-out menus in UI2.
Thanks mikeholczer…
I have it now thank you all… I misunderstood the procedure, I was lead to believe I needed to load the firmware via ftp or ssh. If my unit ever “bricks” I am screwed. Because I could not get it to link up.
Yes I am still unhappy with the product/company or maybe it is the path of follow through on concept.
I am excited about the concept, . . . I am looking forward to a completed consumer product.
I am not happy being a part of your profit. It is a cheap way of perfecting a device for consumer sales, to have a few (unpaid) users who are willing to test modify and develop drivers and modules to later be sold to the general consumer for a nice profit.
Most products I purchase have been tested, completed, and documented. I normally have to find the loop-holes or back doors to get it to do some advanced options not intended for consumer use. But not off the shelf.
With all of the advertisements I saw, this was supposed to be a simple device. Not true. Well, at least for me, it is not as straight forward.
OK, I am done complaining. I have decided to keep the product and hope for a better user interface.
Is it just my unit? Every time I plug a device into the Eth1 port (yes I know now it is the wrong one) the Vera unit loses the network information. If I am not the only one, this may be worth noting somewhere.
