As I don’t know your email address or Vera serial I can’t tell you if it got through or not.
By default if your report was submitted you should see a message like this:
It could very helpful for us if you could post here the exact string that you enter in the Trouble Report fields, that cause to not finish. It could be possible that some combination of non-alpha-numeric characters can cause this, but as I’ve tested in version 541 this should be solved.
Just sending one now. Full tech support was enabled. I waited 5 minutes before submitting this - Vera had not finished yet.
Name is David Zeller
Phone info is blank
Email address (not listed here to avoid spam, but has no strange characters) is email@email.com
Message text is: This is for CJ - test submission to determine why tech support requests aren’t always showing finished.
just updated to current version and now sending one
full tech support enabled
Send tech support my logs and configuration files enabled
email: bdefhkl@no.rt (chars sorted)
desc: test report for cj
still (after 5 minutes) “Sending report, please wait …”
I’ve received all the reports, the problem seem to be with the communications between js and the cgi, that sometimes crushed because of a cat command used in it and didn’t output the trouble report no to the user, but we did get all the reports. Now We’ve made the page standalone and also it’s showing progress to the user.
