OK, this started after my upgrade to the latest firmware on my Edge. I contacted Vera tech support they di a downgrade through remote. Their explanation was it was due to the Harmony plugin here is the response"Thank you for contacting Vera Support.
I?ve accessed the unit and downgraded the firmware to the previous version but there seems to be an issue with the Harmony plugin that causes the engine to reload.
The error message is the following: ?Harmony Control : CMD: Failed sending command get_config to Harmony Hub ? errorcode=503, errormessage=Unknown Harmony response?
I can try to restore a backup on the controller if you provide me a date when it was working correctly.
I look forward to your response.
Regards, "
I removed the Harmony plugin and no help reinstalled it still no help. I purchased a new Vera Plus and did a fresh install un-pairing each and every device from the Edge then installing to the Plus. All seemed good in the start and then “BAM” same issue. I will give it a command and 1 to 1 1/2 minutes is will finally execute and all commands seem to work fine for about 15 minutes. I have a tech support ticket in but have had no response (this is for my plus with fresh install). so after days of screwing with both the vera and plus I still do not have a functioning system. I have had no issues other than very minor ones I caused in the passed. I am also getting a few error codes, I do not really understand the code but here is some of the errors I am seeing
ZWJob_PollNode::ReceivedFrame job job#672 :pollnode_sms2 #50 dev:163 (0x1071d98) N:50 P:20 S:5 Id: 672 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 50 got 19
ZWJob_PollNode::Run job job#666 :pollnode_sms2 #53 dev:167 (0xef4960) N:53 P:20 S:1 Id: 666 ZW_Send_Data to node 53 failed 1 req 0x11da968/1 abort m_iFrameID 0 <0x76b24520>
01 12/30/17 20:03:15.099
ZWJob_PollNode::Run job job#666 :pollnode_sms2 #53 dev:167 (0xef4960) N:53 P:20 S:1 Id: 666 node 53, NO REPLY FROM NODE
Also one quick question, what do the colors of the line in the luaupnp mean? I see white, yellow, red, and some purple text towards the end of a line! PLEASE ANY HELP is greatly appreciated. My system is all but useless at this point and I have a very irritated wife!
