Synology Surveillance Station - Recording Control from PLEG
I have been changing my motion detector and camera setup. This caused me to revisit the code for starting and stopping external camera recording on the Synology Surveillance Station. I have made the code more suitable for use with PLEG - which has some advantages over using normal Vera scenes. The main benefit is that PLEG will check its timers after a restart so can stop a recording that was started before Vera crashed.
I have my ip cameras set to continuously record one frame/second onto their internal microSD cards. With careful choice of resolution and H.264 compression bit-rate, I can get 14 days of history on a 16GB card. This is a useful feature as it reduces the loading on the network and NAS drives. The recordings would be lost, of course, if a thief stole the camera! ::slight_smile: To back this up, I use PLEG to start a seven frame/second full-resolution recording of a camera on the Surveillance Station when a nearby motion detector is tripped whilst the house alarm is armed. PLEG will stop the recording after a timed interval.
The following routine is placed in PLEG’s Startup LUA. It provides the function SsRecordControl(, <camera#> [,<camera#>]). Where is either “start” or “stop” and <camera#> is one or more camera numbers previously set up on Surveillance Station and separated by commas. E.g. SsRecordControl(“start”,1,3) starts recording cameras 1 and 3.
[code]–
– Start or Stop recording one or more cameras on Synology NAS Surveillance Station
– SsRecordControl(action, camera# [,camera#]…)
– action = “start” or “stop”, camera# = 1 to cameras on NAS-SS
function SsRecordControl(…)
local args = {…}
if #args < 2 then luup.log(“SsRecordControl: Missing arguments”) return false end
local action = string.lower(args[1])
if (action ~= “start”) and (action ~= “stop”) then
luup.log(“SsRecordControl: Invalid action: " .. args[1])
return false
– Request session ID from NAS-SS
local nasip = “192.168.1.253”
local account = “XXXXXXXX”
local passwd = “XXXXXXXX”
local sidurl = “http://”..nasip..”:5000/webapi/auth.cgi?api=SYNO.API.Auth&method=Login&version=2"..
“&account=”..account..“&passwd=”..passwd..“&session=SurveillanceStation&format=sid”
local status, response = luup.inet.wget(sidurl,30)
local sid = string.match((response or “”),‘{"sid":"(.+)"}’)
if sid == nil then luup.log(“SsRecordControl: No SID from NAS-SS: " .. (response or “nil”))
return false
– Request action for each camera in argument list
for icam=1,#args-1 do
local cameraid = args[icam+1]
local ssurl = “http://”..nasip..”:5000/webapi/SurveillanceStation/extrecord.cgi?“..
“api=SYNO.SurveillanceStation.ExternalRecording&method=Record&version=1&cameraId=”..cameraid..
“&action=”..action..”&_sid="..sid
status, response = luup.inet.wget(ssurl,5)
local success = (string.match(response or “”,‘{"success":true’) ~= nil)
if success then luup.log("SsRecordControl: Camera “..cameraid..” “..action)
else luup.log(“SsRecordControl: Error on “..action..” camera “..cameraid..”: " .. (response or “nil”))
– Terminate session
local endurl = “http://”..nasip..”:5000/webapi/auth.cgi?api=SYNO.API.Auth&method=Logout&version=2”
status, response = luup.inet.wget(endurl,5)
end[/code]
This function can now be used in PLEG Actions by placing a single line into the LUA tab. Here is a simple example of the PLEG configuration:
Triggers
AlarmSet Alarm Armed is On
BackPIR Back PIR is Tripped
Schedules
TimerRecB StartType: Self ReTrigger, StopType: Interval, 30 seconds
Conditions
BackStartRec [Repeat=No] BackPIR and AlarmSet and (AlarmSet; BackPIR)
BackStopRec [Repeat=No] !TimerRecB and (BackStartRec; !TimerRecB)
Actions
BackStartRec This PLEG, StartTimer, timerName=TimerRecB
LUA: SsRecordControl(“start”,1)
BackStopRec LUA: SsRecordControl(“stop”,1)
Very cool, did you mean to have your password set in there?
Is there anyway to go back in time after a motion detector fires? I’d like to be able to pick up images taken 1 second back, 10 seconds back perhaps 15 and 30 and email all of those to myself
No, thanks for the heads-up. Now changed and revoked. ::slight_smile:
Is there anyway to go back in time after a motion detector fires? I'd like to be able to pick up images taken 1 second back, 10 seconds back perhaps 15 and 30 and email all of those to myself
There’s a setting in Surveillance Station that controls the amount of pre-trigger and post-trigger recording. I have my pre-trigger set for five seconds so I can see what caused the PIR to trip.
@RexBeckett, I want to use this Lua to simply enable/disable a camera when my alarm is armed. I have been trying to figure out how to make the needed changes based on the API and test it in Lua for Windows, but with the luup extension commands in there, I can’t run it on windows. Can this be converted easily to Lua Socket or was there a reason it needed to be luup.inet?
