Switch or solution for a 6-20P outlet (250V, 20A)?
Has anyone come across this or set themselves up with a switch for a high voltage outlet (250V, 20A, the outlet type is 6-20P). In our house, this plug is used for an air conditioner and I wanted to get something that could handle controlling it (on/off). The air conditioner doesn’t have IR or a remote, so that pathway isn’t an option.
Thank you in advance!
coverthawk
The Intermatic CA3750 is the only Z-Wave device that I am aware of, that can handle a 5Kw load.
i would just use a heavy duty relais (which will be a lot cheaper then a zwave switch supporting it)
somethings like this: http://goo.gl/4VYIE
and have a tiny z-wave relais switch it.
like a fibaro micro switch.
the one o found is quite expensive because its brand, there are much cheaper ones out there.
