Greetings,
I’m running 3 Linear switches… two are dimmers (WD500Z-1) and one is an on/off switch (WS15Z-1). The on/off switch (WS15Z-1), isn’t included in the shortcut to “Turn All On”. How do I get it included with the other two switches? I’m using a Vera3.
I am not sure what is sent to the zwave devices when you do the “turn all on” shortcut, but if it is using the “all on/off” class of commands, you will need to enable the switch to respond to that class of commands.
