So I had to search far and wide and didn’t really get the results I needed.
This plug-in has no information about how to make it work. Someone please document.
Here’s what I found so far:
Put the port number :5000 at the end of the host.
Hello,
I’m the author of the plugin.
You will find some informations here (in French) :
[url=http://www.touteladomotique.com/forum/viewtopic.php?f=48&t=16306]http://www.touteladomotique.com/forum/viewtopic.php?f=48&t=16306[/url]
For the moment, the plugin is still in developpement : the new version of Synology Surveillance Station seems to have connection problems.
I will create a dedicated post when the plugin wil be able to handle the connection problems.
And using translator to English
Subscribing to this for later…
I have downloaded this plugin as well, as I use Synology Surveillance Station and would love to be able to view and control my cameras, as well as trigger scenes in my Vera 3 UI7. Would you please advise how the plugin development is going? Thank you
I got it working for some months after reading:http://forum.micasaverde.com/index.php/topic,33759.0.html
But after the latest updates of SS it’s not working any more. Hopefully it’s easy to fix…
Hello,
the plugin is working on my VeraEdge (SS 7.1-4141)
I will check if I have pushed all my modifications.
Thx Vosmont. Working again after update
