Are there any tricks to getting Authomation to operate the phantom zones created by the RadioRA application? Guessing only Z-wave and insteon are supported, but just wanted to make sure I’m not missing something obvious.
Also have Z-wave switches on the same controller and Authomation works fine for these.
Verlite (1.5.408) / Motorola Xoom Jelly Bean / Motorola Droid Bionic (2.3.4)
I would most likely need to add support for them. How are they added to vera via a plugin?
Yes. App available from within the micasaverde website. mine is controlled by a parent usb to serial adapter plugged directly into the VeraLite.
Can you point me in the direction of the plugin so I can have a look to see what is needed for support?
MCV → Apps → Install Apps → look under system interfaces
Lutron RadioRA
Thanks I’ll look into it.
